Most of it yes, had only shortly before removed tiles so still need to scrape some more off. This is where the bath was and the skim coat over the render was quite crumbly and practically fell off leaving the finish you see in the pic.Have you taken all of the loose finish plaster off
How much of the undercoat plaster is visible %
Thanks for the advice Wrighty. Is reskimming the walls the only way? Is this is the best option then so be it. Can l not just skim the areas that sit back of the render that is left behind? There must be a 3mm difference.Remove all the loose plaster seal all the walls with a mix of 3 parts water to 1 part unibond once dry apply a neat coat of unibond, this will leave a slight tack to the surface when dried then the whole room will need reskimming , this will need time to dry maybe a week before sealing with a quality acrylic tile primer 2 coats follow the manufacturers instructions good prep will give you a great finished job. Cheers kop
