Discuss wall preperation in the Australia Tiling Forum area at TilersForums.com.
David Rowell
So today i went to have a look at another splash back job, the walls are bowing in like a banana.
Would you build it out and trowel flat or would you prime it and then build the adhesive up on each tile or if different
please share your method
And also do yous tile walls plumb? Or tile the way the wall is going as long as its flat?
TIA :smilewinkgrin:
Hey David,
thats almost a "how long is a price of string" question! Every job would have to be taken on its own merit. Your a joiner, sure your trade is no different. I've used all of the above methods before plus more! If it's an enclosed space I've over boarded with 6mm Hardie. If not I've skimmed walls flat with adhesive before leaving for the day and packed them out as I go. It's all about aesthetics! If you're a shuttering chippy you won't get it, but if you're a second fix joiner then u will! Take a route you're comfortable with. That'd be my advice.
Generally FLAT works fine...... Unless it doesn't! You already know the score! :thumbsup:
David Rowell
Hey David,
thats almost a "how long is a price of string" question! Every job would have to be taken on its own merit. Your a joiner, sure your trade is no different. I've used all of the above methods before plus more! If it's an enclosed space I've over larded with 6mm Hardie. If not I've skimmed walls flat with adhesive before leaving for the day and packed them out as I go. It's all about aesthetics! If you're a shuttering chippy you won't get it, but if you're a second fix joiner then u will! Take a route you're comfortable with. That'd be my advice.
Second fix 3fall couldnt stand doing shuttering all day long I dont think id get any job satisfaction like. Cheers for the pointers :smilewinkgrin:
White Room
What:yikes:
Reply to wall preperation in the Australia Tiling Forum area at TilersForums.com
23K
Deleted member 57709
Hi. I'm relatively new to tiling, and have begun offering it as a service alongside my existing...
5K
Hey guys, I normally post over in diynot for general DIY but wrt tiling over timber I need some...
28K
Just Rizzle
Hi guys, Last time I posted here I was having a first attempt at tiling the walls in a shower...
Waluigi
wall preperation
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
