WEBER addy/grout
Diamond Pool Finishers
well i must say i like the addy, a bit like Bal where you used to have an additive to make it - even more flexible , not even sure how we judge the flexibility of adhesive anyway ? .
the grout is a bit weird as you mix it it gets very very dusty, then all of a sudden it come's together ,not sure if i like the grout yet :thumbsup:
how do you guys find it ?
I agree,I used their grout for the first time last week and it was very weird!.Just kept mixing it until it came together tho.
That is the water repelling properties and polymers.
Thanks Dave , i did think that might be the case :thumbsup:
a bit of a clash really ,as i think they go on about there Low -dust Adhesive , then they have a grout that more than makes -up for it lol:yikes:
The absolute key to using weber.joint pro is you have to leave it half an hour before you start washing it off, minimum
it was designed so you could grout a larger area before you had to stop
Sent from my GT-S5830 Tapatalk 2
On porous tiles this is too long, the grout has set solid on the face of the tile way before half an hour has passed. I used it on polished porcelain and it was a pig to get off the tile, wouldn't dare use it on a textured tile.
Really!?! I've never done that, and use it all the time. I usually give it about 15mins, and can't say it's ever given me a problem. 😉
WEBER addy/grout
Diamond Pool Finishers,
beanz,
beanz,
