Weber set plus suitable with underfloor heating or not?
yes from CTD and is very nice to use, well the white slow and rapid set S1 is, don't like the grey
Looks like sp es in a trade bag. Lovely adhesive that Julian, not tried the rapid version but I know the grey is really nasty to use
It stating on the technical datasheet that weber standard set is suitable for heated floors & says as follows.
The heat must be turned off & should been turned on gradually at least 5 days after tiling.If the substrate is timber it must be overboarded * weber AD250 used in the mix hope this helps
your right Andy, my problem is it was clearly stated on the front of the bag and now its not. My first point of reference is the info on the bag.
if I go into a shop to buy some floor tile adhesive for, say, porcelain on wet ufh and BAL, Ultra, Ardex and Mapei all clearly state 'suitable for porcelain and ufh' on the bag I will pick one of those. I will not search the web for the spec sheets to find out what each one does, hence I will not use Weber set plus eco.
Andy Allen,
Blunt Tool,
Andy Allen,
Blunt Tool,
