Wall and Floor Tiling Standards BS 5385 Part 1 and 2 British Standards, ISO Tile Fixing Standard.
Welcome to TilersForums.com, the place to discuss all tiling standards whether British Standards in Wall and Floor Tiling, BS5385, or ISO European Standards for Tile Fixing.
Tiling Standards
Wall and Floor Tiling Standards for the UK: British Standards in Tiling.
Discuss Weight of Porcelain in the Tiling Standards area at TilersForums.com.
tfs
basic example of how a stud wall can be reinforced.
Gazebo
Could i not just use normal plugs and screws with metal washers (stainless steel obviously)
where can you get the plastic washers etc.?
I have used the marmox plastic washers before on marmox board but they seem to still sit of the board a good 2/3mm once fixed, was i doing it wrong.?
The aquapanel thermal screws and washers are much better on marmox and wedi boards. don't know if the little reccessed bit in the middle of the washer will pull into hardibacker though.
Gary
Reply to Weight of Porcelain in the Tiling Standards area at TilersForums.com
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
A question about mitering and matching epoxy colour I'll be working with some pinkish matt...
Hi, I’d appreciate some help with lay out for four walls with following measurements. I want to...
Weight of Porcelain
Tiling Standards
    Votes: 9 5.5%
    Votes: 17 10.3%
    Votes: 12 7.3%
    Votes: 46 27.9%
    Votes: 21 12.7%
    Votes: 39 23.6%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 5 3.0%
