Wet cut circular tile saw
i keen to hear from anyone that has or has previously used or even seen a wet circular tile saw and what their opinion is.....
I’ve been looking at this one
For a small job recently, ripping some 20mm quartz, l used a diamond blade on a Makita plunge and rail saw, worked a treat, if a bit tricky whilst using saw with one hand and a hose in the other. - okay for a one off job though.
Been looking at these, I’ve got a 1800 job coming up , planks , I’ve ‘only’ got a sigma 128 max, so was thinking of one of these with the rail
The reason I’m asking is that I have a 22mm quartz coming up. What plunge saw did you use mate?
llevram,
Bond,
llevram,
Bond,
