Wet cutter?
There is a phrase..
If in doubt try one..:thumbsup:..
Honestly i was blown away compared to the likes of marcrist the DNA is top dog.
Paul
Just trying to offer my input as an experienced tiler who has used a multitude of methods, ALL of my cuts are spot on every time.
For me, grinders with the right blades & a steady hand are quick & easy to use & more transportable. I have over £1500's worth of Rubi & Norton wet cutters in my garage that I hardly use.Personal choice.
Use whatever you feel comfortable with. As long as the end result is good,then who cares !
Im with Yorkshire 100 % here , ive got 4 table saws and a rodia bridge but my makita grinder with a marcrist blade is used the majority of the time when conditions prevail , the only time i have used a wet cutter recently was cutting 600x400 trav ... :thumbsup:
The Rubi porcelain grinder blade is well worth a try.,
Surpasses Markrist. No chipping,do not use on tiles other than porcelain or you will shorten it's life & results !
Specific diamonds & bonding are used on different blades dependent upon their specific use. So, if you use a blade designed for hard materials on soft materials & vice versa,you will drastically shorten their life & effectiveness !
Good advice!! the angle grinder is the tilers best friend and its the one piece of kit i wouldnt be without...:thumbsup:
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
