Tiling Tool Suppliers
Discuss Wet cutter? in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
Y
Yorkshire Tiling Services
Paul
Just trying to offer my input as an experienced tiler who has used a multitude of methods, ALL of my cuts are spot on every time.
For me, grinders with the right blades & a steady hand are quick & easy to use & more transportable. I have over £1500's worth of Rubi & Norton wet cutters in my garage that I hardly use.Personal choice.
Use whatever you feel comfortable with. As long as the end result is good,then who cares !
Y
Just to add,a grinder seems to some,a very under rated tool.
Did a 100 metre slate floor earlier this year in a barn conversion, tiles were 600 x 400 x 15mm thick. Majority of cuts were to edges,which were to be covered with 20mm thick skirting board.
I took my 9" Bosch Pro grinder with a dry cutting stone disc. One good quick pass with grinder then knock off waste & job done.
Mate of mine brought along his very expensive Rodia bridge saw,which took ages to set up & lug around,did lovely clean cuts,but was comparatively very slow. He left it at home after day 1 & used my grinder.
Although my cuts are good, there is not always the need to have perfect edges. Speed is often more beneficial.
DHTiling
Of course....:smilewinkgrin:
Tradetiler.. TradeTiler.Ltd Montolit Diamond Wheels
It is not the machine that does the cutting it is the blade, the machine is purely the power source..:thumbsup: but you do need some good power to cut thick materials..:smilewinkgrin:
But no grinder sizes.. i will race you my DNA/Dewalt combo against your grinder..:thumbsup::thumbsup:
Y
Never used one,heard they are good.
andy-p
Paul
Im with Yorkshire 100 % here , ive got 4 table saws and a rodia bridge but my makita grinder with a marcrist blade is used the majority of the time when conditions prevail , the only time i have used a wet cutter recently was cutting 600x400 trav ... :thumbsup:
Y
The Rubi porcelain grinder blade is well worth a try.,
Surpasses Markrist. No chipping,do not use on tiles other than porcelain or you will shorten it's life & results !
Specific diamonds & bonding are used on different blades dependent upon their specific use. So, if you use a blade designed for hard materials on soft materials & vice versa,you will drastically shorten their life & effectiveness !
andy-p
Good advice!! the angle grinder is the tilers best friend and its the one piece of kit i wouldnt be without...:thumbsup:
Reply to Wet cutter? in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
HI FOLKS. LOOKING TO EXPAND ON MY TILING TOOLS AND INVEST IN A WET TILE CUTTER. WITH SO MANY...
Hello, I hope you can help. I'm get despondent cutting 9mm glazed porcelain tiles, 300 x 900mm...
Hi all, I’m after a new hand held wet & dry saw cos my dewalts had it, and been looking at the...
Hi all. New to the forum. Transferring my skills from DIY to making tiling a profession. What...
Maciej
Popular Tile Cutter Threads
Wet cutter?
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
