Wet Floor Leaking
I,ve had a problem like this before on a wet room that I had done,first thing poured water over the floor no leak,then poured water on to the walls no leak, it turned out to be the shower control,might be worth checking that.
I started reading this thread last night and was thinking along similar lines. Its quite a wide water mark down the wall. You say it leaks when water splashes the wall. Have you checked its not a leak on the outlet of the valve? Which ill presume is built in?
Just bumping some of the older popular (sometimes not so popular) threads. Probably wont be current discussion these days but I just need to do it. So just ignore the thread if it's not current for you.
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
