Discuss Wet rooms in the UK Tiling Forum area at TilersForums.com.
Robsud11
Thanks John we have re done the floor area by removing existing tiles and adhesive which had cracked. New tiles are now laid and grouted using bal micromax with gt1. We have not used it as yet even though we where told to wait 48 hrs before using shower it has now been 5 days since it was grouted. Bal state to wait 2 weeks before using if in a shower area. With this in mind should I wait 2 weeks before adding a sealer or can this be done earlier thanks
Time's Ran Out
Remember the sealer is only to close the pores in the grout to stop penetration/discolouration and is not to seal any cracks that have appeared.
Some grouts do shrink on drying and this may be the case, but a repair/regrouting will be required before use.
Was this 'wet' room floor fully tanked and what preparation was done before tiling?
Robsud11
I have had the tiler back and he reckons its just shrinkage. It's only a very small area where this has happened, other areas are fine but the grout has slightly shrunk a bit. No one has been in the room until yesterday and the hairline cracks were already there. It will be 2 weeks tomorrow since it was grouted. Its all been tanked correctly and he has used all BAL products ( flexible adhesive) sub base has 2 layers of 19 mm mariane ply and 10 mm therm board. A 1.0 x 1.0 wet board from topps tiles was used
Reply to Wet rooms in the UK Tiling Forum area at TilersForums.com
  • Sticky
Shower Tile Repair - Tile Waterproofing in Brownstown MI. Schluter wet room conversion 24h...
Hi - looking for a bit of advice if anyone has experienced this. Hands up I am completely...
I could use some help from everyone! The floor mosaic tile was recently retiled over a tile-redi...
Wet rooms
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
