Discuss What do tilers class as hard to master in the British & UK Tiling Forum area at TilersForums.com.
diamondtiling
what do you mean by layers?
1.remove wc and wash hand basin...dont attempt to cut round them.may need plumber
2.ply floor min 6mm depth ??
3.use flexible adhesive
4.plan job,suggest straight line from door as if you are marching in ...then row by row then cuts
5.let set ....grout
Far too thin ply for a floor, 12 mm at the least and only if you have strengthened the floor with extra noggins and screwed everything tight.
What are the tiles you are using?
You need to apply bond to the underside and edges of the ply.
Gazzer
The client is the hardest thing for a tiler to master. i am sat at home at the moment and was due to be at the house at 8am...a journey that would take 45 minutes in decent weather. I cant get further than 2 miles from my home due to the snow that fell last night. So i thought it was best return home...just after 8am a phone call from irate client asking where i am.
I will wait a while and try again :mad2:
Aston
2 things stand out for me..
1. good fluent use of the nippers takes a little time to perfect. lots of practicing on various tiles is the only answer imo.
2. setting out awareness!! you can be great at prep work, and skillfull at cutting but that all round awarness of ensuring your setting out an design features work perfectly becoming second nature is another time bearer..
just take your time graig and enjoy the process and what it makes you mate..dont put time limits on things it will only put you under unecessary pressure. respect the trade but try not to make it bigger than what it is and then you'll approach it more thoughtfully & confidentally.
ed..
Reply to What do tilers class as hard to master in the British & UK Tiling Forum area at TilersForums.com
Hi everyone, With a kitchen renovation, Mrs choose the white mirror quartz floor tiles from a...
I've bought what I thought were floor tiles for my bathroom. They are 600 x 300 x 8.5mm ceramic...
Ceramike
    Votes: 9 5.7%
    Votes: 15 9.6%
    Votes: 11 7.0%
    Votes: 47 29.9%
    Votes: 19 12.1%
    Votes: 37 23.6%
    Votes: 4 2.5%
    Votes: 21 13.4%
    Votes: 18 11.5%
    Votes: 17 10.8%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.5%
