Guest viewing is limited
Discuss what do you think about this kind of tile in the UK Tiling Forum area at TilersForums.com.
Time's Ran Out
here is a job I tiled using them
That's the one - Sorry Gary I thought it was your job I mentioned earlier but its an age thing!
All I do remember was its as good as I thought it was from memory.
If you had a minute it would be helpful if you could describe the pitfalls to this type of tile for the thread starter as I think they are not aware of its porosity and location of useage!
IMO this material is too absorbent to be used outside.
Spud
when ever i fit these tiles I always install them using the sand and cement method ,firstly I soak the tiles over night to reduce the suction from the tiles once fitted and thorouhgly dried out I impregnante the tiles with impregnotor and finish with paste wax buffed off with a rotary buffing machine ,as these tiles are cement encaustic it is very common to get effloresence even when sticking them with adhesive, if this happens i normally use wire wool to clean them and it seems to do the trick I would recommend 1 mm joints as any wider looks terrible with these tiles imo ,they cut nicely on a wet cutter never tried scoring and snapping them but I imagine a block cutter would work very well with these types of tiles, I cant really see a problem with using these tiles outside other than slip resistance issues and freeze and thaw issues (which could be dealt with with uncoupling membrane )
Reply to what do you think about this kind of tile in the UK Tiling Forum area at TilersForums.com
HI, Excuse the length and new thread, but it reads super fast. I could use some advice. There...
eric123
E
Dear TilersForum Thank you so much for the outstanding advice and expert information over time...
Hi all, would love some advice In my new house we are putting a kitchen into a 30sqm room at...
richiedc
Hi We've knocked through our kitchen and dining room and taken up old stone/porcelain tiles in...
7K
Balham SW12 0NJ,
