Discuss What grout and sealer to use in the British & UK Tiling Forum area at TilersForums.com.
GazTech
Hi Andy, welcome to the forums. Can you tell us the type of porcelain , polished porce is the only one that requires sealing.Adhesive needs to be flexi or have porcelbond for it to stick,and grout needs GT1 additive added for it to stick to the sides when grouting. Grout wise i suggest this stuff.....Gaz
BAL Microcolour Wide Joint Grout available in Ebony
A fast setting, efflorescence free, water and frost resistant cementitious grout with water repellent properties and built in Microban® antibacterial protection to inhibit the growth of bacteria and black mould. Suitable for use with ceramic tiles, porcelain, marble, natural stone, glass and fully vitrified tiles with joint widths from 2-20mm in interior and exterior locations including power showers. The addition of GT1 makes this product suitable for use with underfloor heating. BS EN 13888 CG2F Grout.
  • Set in 5 hours
  • 12 colours available
  • Water repellent
  • Anti-bacterial
GazTech
thanks very much for your quick response they are polished black tiles does w=this make any diffrence ive only got a 6mm x 6mm trowel will i need a 20mmx 10mm trowel to applie adeshive ive got adhesive for my tiles so that ok
10mm is required for this big tile, you must use an impregnator sealer suitable for polished porcelain..I rate the Fila one but see what is available in your local merchant....Gaz:yes:
GazTech
mapei ultra colour plus could be used but only do a small area at a time as it dries fast also wear rubber gloves .as it will stain your hands also throw away sponge afterwards and mask off skirting boards
Spot on advis Guy mate....you have to shed skin to remove black grout if gloves not worn.....lol
Reply to What grout and sealer to use in the British & UK Tiling Forum area at TilersForums.com
Hi I have just had my wet room tiled and after one use the cream coloured grout has gone black...
Had new bathroom by a builder who has subsequently gone bust and after 6 months the floor has...
    Votes: 9 5.3%
    Votes: 17 10.1%
    Votes: 12 7.1%
    Votes: 48 28.4%
    Votes: 21 12.4%
    Votes: 40 23.7%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.6%
    Votes: 19 11.2%
    Votes: 17 10.1%
    Votes: 8 4.7%
    Votes: 5 3.0%
