Guest viewing is limited
Discuss What make 115 grinder blade should I buy? in the UK Tiling Forum area at TilersForums.com.
U
united
Re: just out of interest what!!
are you using it to cut or grind ? we use Exakt saws for cutting but for grinding i use a Fein supercut which has different sized heads and also diamond blades for cutting etc.
plus wood blades for taking off bottom of doors and architraves. bit pricey for the supercut but you get your money back our job (restoration would be near impossible without them) be back to tiny chisels etc . look up Fein or Exakt on web.
are those the JML ones? I have looked at them but didn't know how long they would last
495
1,118
Somerset
Diamond blades are manufactured to suit differing hardness of materials you will be cutting.
There is no such thing as a general ( suits all ) diamond blade.
If you wish to save money in the long run, then purchase a diamond blade for hard materials and one for soft.
However,when the blade you are using for hard tiles starts to become ineffective,then you will usually find that it will quite adequately cut ceramics for some time.
Diamond blade - Wikipedia, the free encyclopedia
Now there's something I have never been told before - ok I am fairly new to tiling, but its amazing how much there still is to learn out there!
And having read the Wikipedia article - there is some useful H&S info re diamond cutters on there too.
:thumbsup:
Reply to What make 115 grinder blade should I buy? in the UK Tiling Forum area at TilersForums.com
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
I just set new porcelain 8 x 8 tile in my rear entryway (3 ft x 3 ft area). I love the results...
