Discuss What sub base for tiles in the DIY Tiling Forum area at TilersForums.com.
Hi. I'm after some advise. I am shortly going to be ripping out water damaged patchy chipboard flooring in our utility room. We have purchased the floor tiles ready for this. Can I use 25mm WBP ply fixed to the joists with noggins on the ends and tile straight to this or is this wrong. Any advise much appreciated.
WetSaw
Thanks. I've just read something about sealing the underside of the ply. What's the reason for this and does the ply need priming for adhesive to bond to.
Ply needs overboarding for adhesive to bond to. Don't stick tiles straight on to ply, not unless you want to be doing it again very soon!
J Sid
British Standard states
6.3.4.2 New timber bases New timber bases should be constructed with noggings between the joists. Water and boil proof (WBP) exterior grade plywood of 15 mm minimum thickness should be screwed to both joists and noggings at 300 mm maximum intervals. The lower face and edges of plywood should be sealed against the ingress of moisture using preferably non-aqueous sealers, e.g. polyurethane varnish, or styrene butadiene rubber, to prevent distortion by changes in atmospheric humidity before being screwed down. All junctions between boards should be supported by noggings or joists.
Reply to What sub base for tiles in the DIY Tiling Forum area at TilersForums.com
We had a wet room fitted by a large company. We have issues with a few large steps where the...
I'm about to start on an upstairs wetroom. There will be wet underfloor heating going in via...
Hi, I am trying to achieve a low floor build up including wet UFH over a new suspended timber...
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Wetroom and Tanking Systems Popular
Sheffield
DIY Tiling Forum
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
