Discuss What Trowel?? Grey or white flexi?? in the British & UK Tiling Forum area at TilersForums.com.
F
Fred
8mm square at the minimum, remember to check coverage on back of tile regularily, if not sufficient coverage then increase notch size
This is providing that the walls are plumb and level ! And they will need to be with those size tiles especially if brick bond !
Totally agree. I used a 12mm trowel on uneven walls back in August.
L
Leatherface
Presumably then, the aim is to have full cover of adhesive on back of tiles after they have been pressed into place? Is there a problem with applying a thick bed of addy or is that the best thing to do??
You can also comb the back of the tile with adhesive to achieve a thicker bed ! Check max recommended bed thickness on adhesive you intend to use.
aspley
Aspley ?
I guess you have already checked walls with your long level ? So you know what you are letting yourself in for ? Are they to be fixed in brick bond ?
Not doing brick bond. The walls are new and very true. I have just had a look at the Dunlop website....it dosen't mention a maximum bed depth. Given that the walls are true what would you suggest?
Thanks for you help at this late hour
Reply to What Trowel?? Grey or white flexi?? in the British & UK Tiling Forum area at TilersForums.com
Some adhesives give info (not seemingly Mapei). I think the Mapei Standard Set Plus would suit...
Hi any advice on what would go with what. I've layed off white tiles on floor with grey...
Hi guys, had some great advice here before so thought I would ask here for advice again...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
