What went wrong...?
All of the above sounds familiar. Nice to see Neal (Sir ramic) posting, hope you are well mate.
There's a good chance it was not dry. Natural drying would need around 20 degrees and 60% rh. The choice of adhesive puts you at risk and whilst SBR can be used it is sensitive to moisture as well. Sanding the floor to remove Laitance and any other surface detritus is essential for correct preparation. If the tiles are coming up clean it is a printer failure as that is the bit that is supposed to stick to the screed and the adhesive sticks to that in turn. You will need to lift the tiles and replace them. I would use a gypsum based adhesive. There are loads about and they are no more expensive than cement based these days.
you know your stuff mate
If the builder tiled the floor then imo he should foot the bill to replace it.
These screeds are notoriously difficult to get right and should only have been tiled by an experienced tiler.
I suspect that this problem is happening to many other people. Other people who are about to have tiling carried out and are doing a bit of research will be helped to make better decisions after reading this post and the helpful advice and links given.
Local to me is a large 5 bed bungalow, that was having a small extension to the dining room. This bungalow is totally tiled. Extension was finished, and when everything was done, I had to extend the original tiling. This place had the older Anhydrate screed when built about 20 years or so........ALL the tiled floors are floating. The whole place has debonded.........it's like walking on a thin sheet of suspended ply. I had to lift a few damaged tiles in this extension, and didn't need any tools at all. The laitence had not been removed AT all. Cement solid on back of tiles.......floor totally clean.....but dusty.
It would cost thousands to put right now..........rough guess, about a 90m. I'm still waiting on that job. 🙂
This was also done by the original builder, who assured the guy "he knew wot he was doing"
Obviously NOT.
What you are describing does not sound like Laitance. It sounds more like segregation which is a screed defect. You should not scabble screeds. They should be mechanically abraded which usually means sanding.
When I say scabbled that's what I mean alan,mechanically sanded
sorry for confusion,my words are not the greatest sometimes,got the two mixed up
There's no way I would think about tiling this type of screed until it's been tested and tested again. The one I have just completed was down for 6 months or so and I used gypsum addy and still worried!
I don't know an awful lot about these screeds so won't really comment. However, it sounds like there may have been a few errors. Leaving latence to ither guts to advise on, the picture you show once the screed is primed looks to me like the SBR was applied heavy and undiluted. Anyone else?
Going back approx. a year I was doing a couple of bathrooms for a customer when his neighbour came round and asked me to look at a problem with his newly laid floor in the large kitchen\diner extension had just been built.
Tiles were lifting in the same way yours are. When I asked how the floor heating was commissioned he looked at me as if I'd called him a Man U fan. The tiles had been fixed before the floor was full dry. This was the result of not having a fully dry floor.
The green is the primer that had lifted from the screed in the same way yours has!
The result being that the kitchen had to be removed, 90m of tiles skipped and re-fixed again. All this was done at the builders expense, he held his hands up and paid for it all (quite a reputable local builder btw).
Good luck but I suspect the whole floor will have to come up, and I don't think anyone will hold their hands up and take responsibility by the sound of things.
What went wrong...?
zoemac,
John Benton,
zoemac,
John Benton,
