what wet cutter do you use??
Nice big bridge saw,QEP yellow cutter £175 @ trade will cut up to 750mm long,and angles over for mitreing(bit bulky though).Baby version of same cutter £99 will cut up to 550mm(very portable)A great portable cutter is the 'D' cut machine from us,£160 has a sliding bearing table(very portable)as good as if not better than the plasplugs master tiler which I used for last 4 years of my career.🙂
Cheers for that Gaz, the D machine sounds good but seems a bit pricey if it's only as good as the master which costs £80. Will go and cheque it out though mate.
Are the other 2 you mentioned available at topps mate??
Yes,but the big QEP cutter is TOS until end of June🙂
i use plas plug contractor plus its ok so far and used it on porclain and slate but when its time for a blade change gonna upgrade to a better one
tony
tony
There is a turbo blade for the plasplugs,...IT IS F'KIN BRILL.........don't be misled though Bast88rds & Queens(B&Q)will not know of its existance!!
Added post information (due to double posting):
Yea but its a biatch to carry!
Are you shadowing me wivers?😕
I have rubi 250 lps, bout 700 quids worth, dont use it much these days, grinder with marcist blade, if your doin it right most ot the cut edges are hidden by skirtings Silicon etc.
Here ya go son have a look at this. I belive its the same as the big yellow QEP one that Gaz has used.
[DLMURL="http://cgi.ebay.co.uk/electric-tile-cutter_W0QQitemZ280114323380QQihZ018QQcategoryZ42127QQrdZ1QQcmdZViewItem"]eBay.co.uk: electric tile cutter (item 280114323380 end time 19-May-07 15:46:36 BST)[/DLMURL]
New cost £350,QEP when back available in July,at trade £175.....Thanks W......the only visible difference is the spray job!!!
I'm interested in the good feedback on the plasplugs wet cutter - It is the version I have been using on my tiling course during my first week, I found it to be pretty good!
I think it was over filled at some point because I ended up getting soaked and walking around with a wet crotch all afternoon!
Anyway, for £110 you can't go too far wrong can you?
Certainly I intend to buy one when my course is over....
Featured Threads
