Wheelchair accessible bathroom needs a makeover, on a tight budget. Help?
L
LorraineJ
Hello.
I have a wheelchair accessible bathroom that the local Council fitted for my son.
The layout is all fine, but I made the big mistake of choosing a white non-slip flooring which has stained awfully. It's a sort of dimpled, thick vinyl that is glued to the floor.
What I'd like to do is have the vinyl flooring replaced with safe, non-porous tiles, which I'd then also use on the walls around the wet areas.
My question is, will it be feasible to re-use the existing level shower tray that is in there, and tile over it? I imagine it will take a bit of scraping to get the flooring up, but do you think it could be used again?
I'm not sure what defines a wet room. I only need the shower corner to be sloped towards the drain, as it is now. There are low, bi-folding doors and a curtain to minimise splashing.
I can post pics if required. Let me know. (Though showing you how I stained my bathroom will be highly embarrassing, lol)
Thanks in advance.
Hi Lorraine,
It sounds like you might have Altro Marine 20 which is extremely effective as a non slip flooring but it's infamous for marking. Altro do a cleaner for it Altro - AltroClean 44
I don't do safety floors but many on the flooring forum do. They might be able to advise how effective the cleaning is. Alternatively ( check it is Altro first with the builder) phone Altro and they can advise on cleaning. This has to be your cheapest option.
Hi Lorraine,
That's what it is, Altro Marine. It rang bells when I read it.
As for using one of their specialist cleaning products, well, I can't see it working on the staining. On the urine stain I've tried Peroxide, Ammonia, Bleach and loads of other cleaning products and it didn't even fade slightly. The red hair dye staining in the shower area has had a few scrubbing sessions too. It seems to be fading gradually as the weeks go by, perhaps it's UV that's having an effect on that.
Would this forum be the best place to find a safety floor fitter then?
The glue that was used on the seams looked dirty too, even when brand new.
Ok, I emailed Altro flooring and described the staining and they suggested I use Altroclean 44plus before going for a re-install.
I've ordered a small 1litre bottle and will give it a try when it arrives. Hopefully, it'll do the job for under £20. If not, I'll start saving.
Thanks for all your help, folks.
Good luck with that.
Hi Lorraine you can lay a new vinyl straight over the top of the old vinyl you just have to cut the old vinyl half way up the co former. that will allow the new floor to to go in the vinyl to tile trim. polysafe hydro colours are a lot better than altro.
Chris
Chris
Thank you so much. That's so useful to know. I would have been scraping the thing up to save on labour costs.
