Guest viewing is limited
Discuss When can UFH be commissioned after tiling? in the UK Tiling Forum area at TilersForums.com.
The Legend; Phil Hobson RIP
I am having a problem with this at the moment, this floor is in screed water heating. I layed a decoupling membrane over a month ago, having been told the heating had been commissioned. I later learned the floor had only been pressure tested, when they did fire up the floor weeks later. Instead of bringing the temp up gradually ( because there is no thermostat, it seems) the heat just went from 0 to full whack.
My problem now is, isolated areas of the floor are showing, what look like shrinkage cracks in the slc over the membrane. These are very small areas, but in two places it seems like the membrane has de-bonded with the sub-floor.
I have had the rep from Mapei down, and he thinks it could be thermal shock. He suggested I remove any loose areas of mat and replace. My gripe is why do the manufacturers of these heating systems not address the issue of having to commission the floor gradually, by not having a thermostat.:mad2:
The heat on those piped systems are controlled via the manifold phil..
So why SLC over the matt..?.. was it a green screed,
No Dave not a green screed, but I rang Mapei to ask as there was a bit of shape in the screed. could I use Trade plan latex slc to fill the mat (rather than using adhesive) and help level the floor. They said yes, the heating system is run from the manifold. I have been told that there is no way to bring it up slowly:yikes:
Reply to When can UFH be commissioned after tiling? in the UK Tiling Forum area at TilersForums.com
hello new here but wished i had found and asked before screed and ufh down but here goes. We...
