Discuss When Do You Uncouple? in the Canada Tile Advice area at TilersForums.com.
F
Flintstone
I have used uncoupling mats before, but not extensively. It's only maybe the last 18 month or 2 years that my local tile shop has stocked them.
When do you personally use an uncoupling mat and when don't you? Materials and substrate.. I understand what lateral movement is, but I have seen people using mats on solid floors I think
One Day
I don't always use them. Heated floor of a large size, yes. Small heated floor, not unless I'm fixing some weak stone. Fresh screed, yes. Anhydrite screed, always (at least until I'm convinced by gypsum adhesive). Typical thought process is highlighted by a job I'm soon taking on... 300sqm of high quality porcelain onto heated anhydrite screed. In theory i can tile direct using gypsum adhesive. Will i risk 15k worth of tiles popping? No way. Its ditra for me.
F
Flintstone
Wood subfloor or lots of windows. Almost all my floors are over wood, so basically every job I do. Things move at different rates and it seems like cheap insurance. An added benifit is most membranes are lighter and easier to work with than hardi.
This is one thing I don't get, what's wrong with over boarding with hardie or no more ply. It's solid and there is not gonna be any lateral movement. Why use a membrane instead ?
Stef
I only decouple when I'm using stone.
I see someone has stated that they use it to go between 2 different substrates.
That's not what Ditra is designed for, there should be an expansion join in the tile face following through from the substrate.
Also through doors you should have a break in the tile between joining rooms.
MW Smith Ceramics
Personally I would never ditra onto floorboards as this won't stabilise the floor, even if it is solid it's too many separated peices of wood for me, I've always over boarded with Hardi backer or no more ply 6mm or 9mm if possible glued with polyurethane adhesive and screwed......bombproof :thumbsup:
MW Smith Ceramics
That gypsum based adhesive scares me too impish!.....don't mind laying the decoupling membrane with it ( Bal rapid mat mostly ) then flexi cement based addy
Reply to When Do You Uncouple? in the Canada Tile Advice area at TilersForums.com
PVA V PRIMERS – WHy you should never use PVA Glue when Wall Tiling Don’t listen to that idiot...
Got a kitchen floor to do and it consists of a concrete floor which then meets a timber floor...
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
