Where to buy tile hand display boards?
stone tiler
Hi guys,
I'm looking to get some hand display boards. Either in coloured mdf or perspex. (need black or white, not sure yet) Also they need to have the carry handle cut out like the boards you find in all tile showrooms.
Does anyone know where I can get them? any ideas on the cost?
Cheers
Monkey
Have you asked your tile supplier? I'd make them myself personally, would probably be much much cheaper.
Your supplier might be able to help. But if it's a certain range, give the manufacturers a call they should be able to sell you some like they do the shops (the probably give them away to the shops to be fair).
Failing that, make some. Spend a day doing the few popular ranges you fit a lot of and it should pay off when you look all professional with customers.
hi monkey1 for display boards olympic display products tel 0145388316 they will deliver in a couple of days hope this helps you may need to by a hot glue gun look on the internet for best deals
i would think it would be cheaper to make them. get a 1/2 " sheet of mdf and use a router to follow a template . you would make them up in a few hours
There normally 2-3£ each +vat per board depending on size. Olympic should help u out, but they can take more than 2 days!. Normal need to order a couple of hundred boards for them to make and you have to pay up front. I would go in to ur local shop and see what you can buy from them. If you make them ourself be careful what u paint them with as hot glue and Silicon can be fussy what it adheres to.
stone tiler,
Perry,
stone tiler,
Perry,
