Discuss Where to start with a straight herringbone pattern in the America Tile Forum / Advice Board area at TilersForums.com.
Hi,
Im tiling the bottom third of the bathroom wall in a straight herringbone (where the tiles are horizontal and vertical rather than on a 45 degree). Im just wondering where to start to make sure the patter doesnt look odd, start in the middle as normal and work out or start in the top corner and have the smaller cuts on the bottom?
Also I need to go around a window reveal and a internal corner so wondering how the pattern carries on around these types of corners. The tiles im using are 300x100 so theres 3 vertical tiles to each horizontal rather than the usual 2 too.
I have searched the forum for 'herringbone' but only one result came up and google isnt much help with the straight pattern either.
thanks in advance.
Paul
GAZ5518
558
EPSOM
Hi,
thanks in advance.
Paul
is this the look that you want to achieve?
if so center wall….. working from top line down…. Turning pattern in corners….
Hope that makes sense
G.
Reply to Where to start with a straight herringbone pattern in the America Tile Forum / Advice Board area at TilersForums.com
Hi all, I've had a go at tiling our cloakroom loo and its going ok, (I am extremely slow, it...
All, I have 600mm by 300mm porcelain tiles for the shower area. The girlfriend wants a vertical...
I'm currently on a DIY project.redoijg my bathroom. So far I've built a bath surround and tiled...
I've committed to my first 450 herringbone job - will be 3 walls of a shower enclosure with...
2 3 4 5 6
71K
Weston
USA Tile Forum Popular
America Tile Advice Trending
Aberystwyth
What member type are you?
  1. DIY Wall and Floor Tiler
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
