Discuss Which adhesive should I use. in the UK Tiling Forum area at TilersForums.com.
bwares
Hi, I've just joined the forum as I am about to tile my bathroom which has now been prepared for tiling.
The walls are now a combination of pasterboard (painted) and sections have been replaced round the bath in aquapanel.
The tiles I have bought are 276 x 361 x 9mm.
I do have a tub of Unibond non slip ceramic wall tile adhesive but on the back it says it can only be used to a thickness of 3mm.
As my walls are not 100% true (there are minor deflections of around 1-2mm), should I be using an adhesive that is thicker? Will this adhesive be strong enough for the tiles?
Brian
bwares
Thanks for the replies.
Yeah I'm in Glasgow, very close to a tile giant.
The flat is about 8 years old and has a thin coat of matt paint on the plasterboard, do you think it will be necessary to remove all of this?
Also do you know what bed thickness of adhesive I should be using? As I mentioned the walls are not perfectly true, one of the studs in the studwork frame is a tiny bit out and the wall comes out maybe one to two mil at this point. I was thinking the thicker the adhesive bed I use, the easier it will be to remedy this.
Brian
Reply to Which adhesive should I use. in the UK Tiling Forum area at TilersForums.com
    • Friendly
I'm having a nightmare trying to establish product info from distributors. For example...
Hi, I have a very small area (1m.sq) on an exterior doorway entrance wall to tile. I would...
TF Group Please Join
