Discuss Which Adhesive when Glueing and Screwing backer board. in the UK Tiling Forum area at TilersForums.com.
Steve H
Hi All,
Job count is growing and loving the experience. Latest question is:
When glueing and screwing backer board in preparation for tiling, which adhesive do you use. I guess it has to be flexible and I know that its purpose is to fill any potential voids between the board and existing substrate rather than stick the backer board. I have used both Bal single part fast flex and Ardex 77 for the jobs I have done to date, I know, very expensive but the jobs were small enough and that is what I was using to fix the tiles. Just wondered if you guys had a preference for a much cheaper adhesive which you could use only for fixing backer boards. Thanks in anticipation for your wisdom.
Steve
Reply to Which Adhesive when Glueing and Screwing backer board. in the UK Tiling Forum area at TilersForums.com
Just wondered what would be best? The original tiles had a few hairline cracks from the house...
    • Friendly
I'm having a nightmare trying to establish product info from distributors. For example...
