K
kenny123
Hi
I am going to be tiling around bath area using 6"x3" ceramic tiles.. using a brick pattern.. 1 mtr high..
the problem is they have been having problems with water getting behind the original splash back ( i am going to be replacing ) this has caused it to come away from the wall.... the spalsh back is a coated board.. one you find fitted in kitchen areas !!! i know..... !!!
also they have a power shower fitted in the bath area , i am worried that this is the main problem of water getting behind the splash back .. and because i am only tiling to the same height.. i just wondered if the power shower would force water behind the tiles..??
any ideas on what adhesive , grout etc.. would be best to use in this situation.
