Which Grout For Porcelain Wall Tiles With 2mm (small) Grout Joint?
Right ....got some grout 3000 mid grey to use on some 600x300 pors on the walls.
Im used to using bal grouts....is it similar to use? Would normally grout 5/6 m2 wiipe it off..let it set for an hour or so and polish the dust off with a dry cloth.
Same method works well with Grout 3000. In a bathroom I usually grout one wall, wash then polish an hour later as you do with BAL. I like my grouts fairly thick mixed too, but it can go off in 45 mins unless you keep mixing it.
They state there grout can do 1-20mm, if it was course it would struggle with the 1mm joints.
Used the grout 3000 today..
What a fantastic grout .....large format porcelain on the walls and I got the perfect finish I've been looking for...can definitely recommend it to anyone else...🙂
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
