Discuss Which is the best way to tile over electric UFH system ? in the Canada Tile Advice area at TilersForums.com.
tony4173
Hi guys,
OK so the customer has done the prep work i.e, fitted the backer boards with flexi tile adhesive and 100's of screws to secure the boards. He's fitted the electrical UFH system and the floor is now ready to tile.Which is the best way to tile over the UFH system ? I recommended to the customer a layer of flexi self leveling compound over the system before tiling to en-sure longevity to the floor i.e eliminating cracking grout joints and possible loose tiles caused by the heat over a period of time.
He says just tile straight over the system with flexi tile adhesive and it will be ok. Just want to ask you guys.
A. Is it hard to tile straight over the system with the wires and what not every where.and how difficult is it as opposed to tiling straight over the self leveling compound.
B. Would you recommend my way or his way ?
And yes i have tiled quite a lot of floors but never over a UHF system.
DHTiling
Encapsulation of the wires in SLC is my preferred method all day long but that does not say you cannot do it the customers way either.. :)
Use the flat edge of your trowel and float the wires in with adhesive to cover over , then back comb the tile with adhesive and bed into situ to create solid bed...
The only down side of second method is that if you have to lift a tile to adjust etc.. then it pulls on the wires.. but it is a method that can be done ..
I prefer to SLC method as then i can work away , safely knowing i will not damage the UFH wires and can lay tiles and lift with no worries etc..
Plus if the customer ever damaged a tile , then it is easier to replace if the UFH has been SLC'd before hand..
Some UFH do say you don't need SLC over the wires and you can tile straight on top of the wires (I did one 2wks ago Warm-Up ProWire).. So maybe the customer has read the instuctions & is going with that.
We all know to SLC is a better way, but also for practical reasons it makes the job easier without worrying about the cables.
I'd never go straight over the cables, too much risk of damage.
If it were me, I'd call round the day or night before and lay some SLC, then it will be ready for you on day 1
tony4173
Thanx for the advise guys much appreciated. I have spoken to the customer and hes getting back to me at dinner time today,he seems to want me to tile straight over the system to reduce the self leveling adhesive costs but i would assume the amount of flexi adhesive needed to fill all the voids,hollows and gaps under the wires would probably cost the same maybe ! I think i might give this one a miss if he don't self level it first. Or, like I said to him on the phone if cracks appear or tiles start lifting further down the line then i cant be to blame as i advised you the proper way. Don't think its worth the hassle if anything does go wrong.
If ya not happy with it, DON'T DO IT !
Martin you can have the job it's in Leeds lol
DHTiling
15m2 kitchen floor i am charging him £***, that's cheap but its only that price because I have done a lot of work in his house over 2 years..What would your price be considering it aint that straight forward tiling over the wires ? is it worth it what I'm charging ?
***quid.... jeeeeez cheapo or wot :)
Reply to Which is the best way to tile over electric UFH system ? in the Canada Tile Advice area at TilersForums.com
Hi there, hoping for some help here. I am about to install a small (2.2x2.5m approx) area of...
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
Hi I have ordered the Wunda Rapid Response underfloor heating for my kitchen. We were going...
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
