Which type of Trowel?
The term solid bed is a trowel that can give 100% coverage of adhesive....
These trowels have notches that are deeper in depth than they are wide between the notches( say for instance 20mm deep and 10 mm between the notch)....the peaks then collapses as you press the tile into the adhesive bed thus closing the narrower section of the toothed bed between the notch , creating the solid bed......
This is also how correctly you mix your adhesive so that it will bed down and create a nice solid fix....you can check this by bedding down a tile and then relifting it and checking how much coverge you have on the back...
With some tiles that have a heavy profile on the back then it helps to back skim the tile to achieve this solid fix......
:thumbsup:
Hi
I currently use 2 types of trowel for my tiling (I'm kind of new). One is a 6mm square shaped trowel, which I mainly use for wall tiling. For floors I use a 10mm square shape. Both work well - however, I'm concerned that the 10mm square is perhaps not the best tool for the job. Reason being is that I always seem to get through a ton of adhesive when flooring - it seems to lay a very thick bed - even when I scrape it to the base level. I thought that a 10mm square should compress down to around 3mm when the tile goes on, but it doesn't appear to. Would another trowel be better? Or is it something else I am doing fundamentally wrong?
Paul
You will soon fly through adhesive when doing floors mate, only expect about 4-5 sqm per 20kg bag.
Without sounding daft, and not meaning to insult, when you say you end up with a really thick bed are you holding the trowel in the correct position when spreading?
How many sqm on average are you using per bag? (20kg)
Not insulted at all - advice is always appreciated.
Holding trowel in the way that seems logical. Trying to keep it at 90 degrees to surface, though obviously it has a slight angle on that, so its more like 60 degrees. I have seen that if it approaches 45 degrees it flattens out the peaks to much. And I've always presumed (right or wrong) that the peaks should be at their maximum possible?
Difficult to judge how many sqm's I get per bag. Reason being is that the 2 large floors that I've done have both needed building up by at least a 1cm in places, so for instance, when I laid my kitchen floor, I was sometimes only getting 5x (45x45) tiles laid. But that was a really thick bed. It needed to be that thick, because the level needed to meet a bi-fold door edge, that was critical to have the inside and outside floors meet.
I find that more often than not I spend my time floating rather than scraping. Even on my current job. A wet room, with 600x300 white porcelain tiles laid on wedi board. Because of the slight fluctuations in the wedi board, its still not a perfect flat surface. So in some parts it needs a 3mm bed on one part of a tile, but on another part of the same tile it needs 6mm - to keep the tile vertical and matching it with the others. As the tiles have rectified edges and are really clean/sharp and modern, their isn't any room for having even a slight error. If one is slightly low, it shows badly.
I blame the builder that put up the wedi board (oops that was me). But it always happens. Because even though the board is flat, when you tape the joints, you still get a 1mm or more build up, which throws the whole thing out. Or you simply have cumulative errors of wall being out.
Paul
Personally I use the Platinum trowels for floors - they produce alternating peak heights and tiles bed down beautifully. Largest format I have used them on is 600x600 porcelain and always got 100% coverage.
I have heard some bad reports on them as well.........some have said that they are very heavy for a trowel and not easy to spread the bed consistently.....:thumbsup:
They are VERY heavy and my grout float has come off the handle already.I was impressed at first with the float but not too chuffed with the rubber coming away from the handle.Still not used my trowels yet though.:yawn:
hey guys, is it ok to use a 10mm x 10mm square notched trowel on floors
just bought one and am seeing you guys are recommending the round notched one!!:yikes:
It isn't the size of the notch that you use that is important, it is the coverage on the back of the tile. If you can get full coverage using a 10mm square notch then that is fine, you can always back skim the tiles as well to help this. A half round 20mm trowel helps to give full coverage easier but you still need to check how you are doing by lifting a tile every now and then to see. If you aren't getting full coverage, then change up a size or take other action so you do.:thumbsup:
pt44,
grumpygrouter,
pt44,
grumpygrouter,
