Guest viewing is limited
Discuss Why you should do a bounce test and then check the floor in the Canada Tile Advice area at TilersForums.com.
Chalker
1,058
Tadcaster
Started a bathroom today, bounced on the floor and in more than one place it was terrible. So instead of taking traps up and fitting noggins ,i decided to lift the whole floor.
heres what I found!
no noggins at all.
no perimeter noggins.
two of the joists were nearly an inch from touching the sleeper wall.
Looks like some work tomorrow!
charlie1
Brilliant example chalker thanks for sharing what do you plan to do to get the beams all sitting level on the sleeper wall? Cheers
Looks like two issues need to be addressed mrT
1, excessive bounce
2, floor possible not flat / level.
Ask yourself. How would you fix these two problems? I know it's hard as your only looking at pics, it's difficult to see exactly what's going on.
Mr Tiler
Same as whitebeam but more than a couple of noggins lol. Also if the joists are too far out and shims can't be used it would be a case of bolting 2x4 to the existing joists but at the correct level and fixing timber to the 2x4's... All theory of course as I have no experience of levelling out a timber floor ;) so please don't slate me lmao
Chalker
1,058
Tadcaster
Thanks for the replies.
im going to run a perimeter nogging, then two rows of 4x 2 noggings going the length of the floor. All glued amd screwed. The sleeper walls are level, so I'm sure I can get the floor flat and level. Will have to do some packing on the sleeper walls, after making all the pipework alterations I've talked the customer into letting me fit 50mm kingspan between the joists, ( extra cost). Then fitting 22mm ply, glued and screwed ready for the aqua4ma wet room tray and floor panels.
thats in theory anyway.
Mr Tiler
You clearly know your stuff buddy... You doing the pipework too? :yikes:
Reply to Why you should do a bounce test and then check the floor in the Canada Tile Advice area at TilersForums.com
Hey guys, I normally post over in diynot for general DIY but wrt tiling over timber I need some...
28K
Just Rizzle
I'm intending to tile a kitchen diner floor, 1/3 of which is concrete but the other 1/3 a...
5K
Rizzle from the Portizzle
I had a job booked to retile 19m of kitchen floor where the house had apperently had a little...
wayfoward
Hi all, I know questions regarding wooden type floors has been asked many times on many forums...
Chalker
Tadcaster
Business Name
Walker plumbing and heating
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
