Wiring up Garden room (Need help on Dali light) Electrical Advice
Wiring up Garden room (Need help on Dali light) Discussion ThreadWiring up Garden room (Need help on Dali light) Electrical Advice
Hi, recently got a garden room and completely wired it up but running into a snag. Is there any way I can use dimmable led batons that have Dali output with just a dimmer switch as I’m having problems getting it to work.
I know usual you have to have a permanent feed at each light and switch wire. Is there no possible way I can just dim it up and down with dimmer switch with just switch wire at each light.
Wiring up Garden room (Need help on Dali light) for the original thread on Electricians Forums
Electrical Advice
Lou,
Lou,
