Discuss Working in the Canada Tile Advice area at TilersForums.com.
G Matharu TFS
Hi all,
im new on here been tiling for a little while currently working on some flats in birmingham, where the contractor is telling me i am working to slow, he is trying to tell me that another tiler was tiling onto plasterboarded rooms in shower rooms and grouting same day and finishing off in 1 day using ready mixed addy, said he was doing 4 kitchen spashbacks approx 5 square meters each a day, this guy must have been termiators brother!!
personally i have never tiled and grouted using ready mix addy ever even got told at college allow to set over night or at least 12 hours so the addy can set go off and bond with the tile is it not true if grouted same day the addy will not cure or will leave a brittle structure prone to cracks upon drilling, anyhow the bathrooms in flats are aprrox 15 sq mtrs and 4 on the floors and the way ive done them is im averaging complete from start to finish 2.5/3days for one bathroom with one window, setting out and starting walls on day1 evening doing the floor returning the following day to finish walls and day 3 grouting and siliconing.
Kitchens i have done 2 per day the grouted both next day all brickwork in kitchens.
would appreciate advice please!!!!!
I
Ian
I've seen people who can do this amount of work in a day, it's madness. The quality is very rarely any good, they don't set out and more often than not don't Silicon either, just grout. It's why I won't even consider commercial work. To do a quality job, requires a certain amount of time and most contractors just want you in and out.
John Benton
1,138
Leeds
Never a truer word spoken there Bri :thumbsup:
John Benton
1,138
Leeds
Yep if a customer says to me they can have their bathroom done in 3 days by another 'tiler' I tell them the quality of the work will not reach your expectations but I'll let you decide whose work will be of a better standard
The D
I did this sort of work for years and years and years and I would have smashed two 15m2 bathrooms per day no problems I did try not to grout the same day I normally left that till Friday. As far as quality well I have never been kicked off site for rough work YET
I think the mentality is all wrong for some people if you want to plod along at your own pace you need to work for your self not a firm.
area tiling
523
n.ireland
I'd be tiling and preping a 3 sided shower in an en suite say 7.5 - 8 m 2 , and floor roughly 4 m2 , plus a splashback per day . Come back next morning to grout, never would I grout the walls on the same day unless it was rapid set! Some contractors haven't a clue about the materials their tilers are using , just c pound signs !
area tiling
523
n.ireland
And their trimming work is shocking !
I
Ian
I probably put all fast tilers in the same boat with what I said in my earlier post, that was wrong of me. It is possible to be fast and accurate but it depends on so many things. What's the prep like? How many windows/boxings/sockets in the room? Can you cut in the room? Does it need trimming? I have tiled a 15 m2 bathroom in a day before but, I'd spent the previous day reboarding it and there were no windows or boxings, just 4 straight walls, I grouted the next day as well so, yes I tiled it in a day but the reality is it took 2.5 days, good prep is what makes me fast.
I think 99% of us on here have done the same (if not similar) work that you're doing.
Be it new build/social/commercial etc.
I wouldn't be surprised if the other bloke did do the work he's on about. Plenty of tilers can, and do knock-out 4 kitchens a day, or 20mtrs grouted. But I wouldn't worry about what others can or can't do.
Its getting a balance between the speed and the quality. Don't compromise your quality, but if you try to speed up a little bit, it will come with tilme.
The foreman won't be bothered if the adhesive is dry or not - he just needs it grouted so he can tick the box & then hassle the plumber to 2nd fix or the decorator to get in, and then its another room completed for payment.
I always refuse to grout until its dry, and they'll just have to wait. I usually get the tub & read all the instructions to the foreman about wall prep, application, 24hrs drying etc. They're not ususally bothered, but they get where you're coming from, & they storm off etc. But I wouldn't be bothered about upsetting no-one on site.
As I've said before, this type of work, and the experience, will in the long-run make you a better tiler. Learning all the do's and the don'ts of what goes on..
Reply to Working in the Canada Tile Advice area at TilersForums.com
6K
F
Good evening all. I need to tile the kitchen floor over the bank holiday weekend. We are having...
13K
Futuregrout
F
hi i have been tiling for a good 4 years now but not to my full potential i have built up a...
terrycoe1
Got to quote for a kitchen floor approx 23m2, tiles are porcelain 600*600 Current substrate is...
Working
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
