Discuss Your thoughts on coverage? in the Canada Tile Advice area at TilersForums.com.
Hi
I layed 4 tiles for a customer in a front door entrance. The customer then wanted me to rip up the carpet and tile the whole hallway in the same tiles. This meant taking up the tiles I layed. They came up with no difficulty and saw there was pretty good coverage in under most of the tiles imo (pics atached). I used tilemaster rapid flex and a 14mm solid bed trowel. What do you guys think of the coverage and would you continue with the 14mm solid bed or used a 12mm notched? 450mm glazed porceline tile.
Concrete screed in a new build which is pretty level and in good condition. Thanks in advance
Matt V
Devon
if mixed correctly I would have expected better from a rapid setting adhesive, but haven't used tile master produces.
Same here, they appear to have come off very cleanly perhaps suggesting the adhesive has set before bonding with the tile.
What substrate are they on?
Thanks for taking the time to reply. Yes I back buttered too. I was a little concerned on how easy they came up. Strong bond to the concrete but not the tile. Bit worrying really. So suggestions are; not mixed correctly or maybe started to go off prior to laying the tile, although I did lay straight away?!?!
Reply to Your thoughts on coverage? in the Canada Tile Advice area at TilersForums.com
Hi guys, Just trying to ask a general question rather than myself having a particular issue...
Hi , I’ve recently completed tiling the floor of a 30m2 orangery and finished upto the bi fold...
Hi all, I've had to come to the arms now to get a definitive solution to a problem I'm having...
2 3
MW Smith Ceramics
U
About a year ago, I had 64 sqm porcelain tiles installed on top of a concrete slab, forming a...
12K
Chichester
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
