Discuss Limestone Discolouration in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
Fraser Tiling
598
High Wycombe
Hello guys,
just fixed 20 metres of 15mm 900x600 tumbled limestone to a screeded floor with underfloor heating using Ultra extended set white flexible adhesive.
When I returned to seal the tiles there was a noticible discolouring to the tiles which I put down to the moisture still coming through the stone.
They were laid three weeks ago and the underfloor heating was turned on a week ago but the tiles still dont seem to be drying to a uniform colour.
I have laid similiar tiles before with the same adhesive and havent had this problem.
Instarmac have seen photos of the tiles and say the floor needs more time to dry and eventually the floor will dry, but Im worried about the tiles being stained by the moisture.
Anyone have any experience with this problem or any advise?
Fraser Tiling
598
High Wycombe
Have you done a test on the stone on a substrate you know to be dry with the same adhesive? Surely this will show whether it's adhesive bleed or a screed issue.
have got Ultra coming to site this week, and am meeting the builder again to run through the floor construction for possible faults there, but testing the tile on a dry screed with same adhesive will be a good indication.
There were some boxes and general building items left on the screed overnight prior to me starting the job, and when moved to prep the floor there was no discolouration of the screed to indicate a moisture problem.
I have used these same tiles recently, or at least they look the same. I went for wider joint as it looked more suited to the size and uneven edge of the time. I used tile master standard set white with no problem, onto an old floor. At 15mm thick, I think it would take a lot of moisture just from the adhesive to reach the surface to that extent. I'm voting the screed is wet still
macten
1,158
Nottingham
if ditra was to be used as a waterproof layer, what happens to the trapped moisture in the screed?
The interconnected air channels between the cavities on the underside of the Schlüter®-DITRA 25 matting remain open. This allows moisture in the substrate to evaporate, therefore neutralising vapour pressure.
Fraser Tiling
598
High Wycombe
Hello Pete, just replying to your post after long telephone conversation, obviously cant say too much but staining resolved by customer with Wexa after Instarmac site inspection.
As explained on phone, customers own results from tests resulted in a satisfactory fix.
Although contradictory to Instarmacs lab results.
I've been exonerated of bad workmanship, and final results are no longer my concern.
Thanks for the interest though Pete, and nice to hear from you again.
Lou
Admin
1,473
Staffordshire
Reply to Limestone Discolouration in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which is very thick concrete. He wants electric underfloor heating but I'm concerned he'll lose too much...
  • Question
  • Sticky
  • Suggestion
Post a New Thread for Each Tiling Job Completed. Rather than using the Show us Your Work Thread - which has more than 500,000 views, and thousands of posts to scroll through - we thought it would...
  • Question
