Discuss What SLC to use over UFL in the Tiling on Underfloor Heating area at TilersForums.com.
Looks like somebody got a work bench in the bathroomOne I did on Friday, I needed to bring it up 10mm so I stuck 10mm squares of board in a few places and brought it up to that. The squares often look proud as they can get a raised bit of leveller sat on top of them
What slc is that Andy?One I did on Friday, I needed to bring it up 10mm so I stuck 10mm squares of board in a few places and brought it up to that. The squares often look proud as they can get a raised bit of leveller sat on top of them
I prefer to use screws to set heights as they can be set at different heights if substrate is unevenOne I did on Friday, I needed to bring it up 10mm so I stuck 10mm squares of board in a few places and brought it up to that. The squares often look proud as they can get a raised bit of leveller sat on top of them
I find doesn't take long to drill and plug.On a wooden floor yes. Not so good on a solid floor!
That because you are better than meIf a floor is already flat and level and I’m fitting ufh I will just pour and not worry about setting height markers.
Reply to What SLC to use over UFL in the Tiling on Underfloor Heating area at TilersForums.com
