Discuss What SLC to use over UFL in the Tiling on Underfloor Heating area at TilersForums.com.
K
Kevin09
Hi All,
I'm finishing an extension off next week by installing a UFL heating system,I've done a few before but not for a while.
I'm happy with everything,but I'd just like to ask peoples thoughts on what SLC to use.
Are some better than others ?
I've got about 34m2 to do if that helps
Sean Kelly
Points
1,068
Ruislip
You are going to get a load of different answers Kevin. I personally use BAL Level Max. It's quite a watery mix but you still need to use a float to level it out. You will probably need about 9 bags of it.......but buy 10 to be on the safe side.
F
Flintstone
I’d be using about 18 bags!
No way 10 bags Sean.
Rookery
About 14 bags.
Area x average depth x 1.7 / bag fill + a couple jic
Therefore:
34mtrs x 5mm x 1.7 / 25kgs + 2 = 14
Spare Tool
Never works out as it should using calculations though, i always get 1 1/2 sqm mtrs per 20kg bag at 6mm thick
L
LM
On a flat floor a bag typically covers 5mts @ 3mm deep, include the cavities around the ufh and a good guide average would be about 2mts per bag.
Spare Tool
Maybe I'm doing 7-8mm deep then, spoze by the time I've stuck the 6mm insulation board strips as guides, the glue and sticking it on the ufh mesh could raise the strips a mill or two, since I've been doing it this way I consistently get 1.5m per bag..
L
LM
Andy your not far out at all with that measurement, you’re better looking at materials than looking for them in my book.
F
Flintstone
I always used to work to 2m per bag but these days I think 1.5 is probably more realistic, your better pouring more than trying to scrimp to the minimum.
Reply to What SLC to use over UFL in the Tiling on Underfloor Heating area at TilersForums.com
