Discuss Limestone tiles water marks days after being laid in the DIY Tiling Forum area at TilersForums.com.
L
Leigh
Hi I’m looking for some advice regarding some limestone floor tiles we are laying. They are coming up with water marks that don’t seem to be drying after around 5 days. They were laid on a bed of white adhesive which is fully across the tiles not just the corners. The floor was coated with pva.
Any advice on why this has happened and if the water marks will dry eventually would be great
Spare Tool
I had a thread up a while ago about limestone that had been blobbed down on a window cill by a builder and @Paul C. came up with this..
I’ve had to register another account.
Hi the product that was referred to earlier in the post is called LTP cement grout and salt residue remover which is an acid replacement unlike LTP grout stain remover whic is an acid and cannot be used on acid sensitive stone, where as the cement grout and salt residue remover can as long as it's not polished stone.
If you need a sample call them and they will drop one in the post.
Reply to Limestone tiles water marks days after being laid in the DIY Tiling Forum area at TilersForums.com
  • Question
  • Question
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
  • Sticky
  • Question
