Discuss Slightly unlevel wall, best way to get around it?!? in the America Tile Forum area at TilersForums.com.
Rutters
It's best to apply the adhesive to the wall first with a notched trowel. Then back butter the tile because they are on the large side. Then only add what's required to the back of the tile where its needed. If the wall is really bad then ideally it should be levelled before any tiles are put on but sounds like that's not an option for you. Make sure your using the correct adhesive and if it's a wet area consider tanking prior to tiling. Hope you used an acrylic primer and not PVA. Good luck 🙏
Cheers for the reply, I’ve always used the all in one primer for most never actually used pva!
Reply to Slightly unlevel wall, best way to get around it?!? in the America Tile Forum area at TilersForums.com
Further to my other post re our hollow tiles issue It looks like our tiler has dot and dabbed most of our floor to accommodate tiling 800x800 porcelain over an uneven floor. The gap from defrac...
  • Question
