Discuss Slightly unlevel wall, best way to get around it?!? in the America Tile Forum area at TilersForums.com.
Points
63
Norwich
Hi, so I’m relatively new to tiling. I’ve got a job where the walls aren’t 100% flat but not the worst. I’ve sealed the old plaster with a primer. Am I ok to dot and dab the tiles, I don’t mean 5 dots with 20% coverage, the dots I’d put on would get a minimum coverage of around a 70% adhesive bed. Is this ok? The tiles are 600x300. Thanks
Rutters
Points
38
It's best to apply the adhesive to the wall first with a notched trowel. Then back butter the tile because they are on the large side. Then only add what's required to the back of the tile where its needed. If the wall is really bad then ideally it should be levelled before any tiles are put on but sounds like that's not an option for you. Make sure your using the correct adhesive and if it's a wet area consider tanking prior to tiling. Hope you used an acrylic primer and not PVA. Good luck 🙏
Points
63
Norwich
Cheers for the reply, I’ve always used the all in one primer for most never actually used pva!
Reply to Slightly unlevel wall, best way to get around it?!? in the America Tile Forum area at TilersForums.com
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few...
  • Poll
Hi, I have a small en-suite 1200 x 2400, with a 1200 x 900mm linear drain tray which will have...
