H
hmtiling
Fair do'sthe reason I do it is to stop the ditra from been squashed an damaged
Unorthodox mate, but each to their own
Discuss Anhydrite Screed Question in the Tiling on Underfloor Heating area at TilersForums.com.
actually, Andrew curry at schluter said to the last attendees that they accept this goes on and it doesn't necessarily reduce or limit the effectiveness of ditra. It does add another potential weakness but done as ray said then it's fine. They did used to say it was a no no though.Fair do's
the reason I do it is to stop the ditra from been squashed an damaged kneeling all over the floor as you lay your sqashing the day lights out of it
Well that's why they recommend laying out walking boards, to protect the Ditra.
Backfilling and laying at the same time has to give a better bond strength surely, cos with the shape of the pockets you're effectively mechanically fixing the tile to the Ditra.
If u put another product in between, then you're relying on two products doing their job, not one!
It would be interesting to know how much experience this screed company has on fitting tiles and stone as their advise is awful.The screed company who solely does gypsum screeds on the isle of wight gives terrible advice to all their customers. They say it doesn't need sanding or decoupling even with ufh and stone! This means i always have a nightmare trying to convince the customers otherwise. In fact I'm naming and shaming Mayhew Easyscreed for their p*** poor advice!
Did you read their website info? It suggests a stiff broom and a vacuum will doIt would be interesting to know how much experience this screed company has on fitting tiles and stone as their advise is awful.
It's taken me at least 20 min to stop laughing.. Fantastic advise for cleaning the back yard but that's itDid you read their website info? It suggests a stiff broom and a vacuum will do
and the survival rate of the tilesDid you read their website info? It suggests a stiff broom and a vacuum will do
Crazy..and the survival rate of the tiles
Don't bother seems the best option here.. Let tilers advise on tiling and screeders stick to screedingCrazy..
Either give the correct advise or don't bother!
I know a a screeding company in Kent whose knowledge of what happens to floor comings after they have gone is excellent but these guys are like hens teethscreeders lay screed there mostly ignorant about what happens when there finished they have done there job y should they give a monkeys what happens when theve left
Reply to Anhydrite Screed Question in the Tiling on Underfloor Heating area at TilersForums.com
