Discuss Bed thickness (600x400) 10 or 12mm? in the DIY Tiling Forum area at TilersForums.com.
Do you mean tooth size of the trowel? It depends how flat your floor is.
How've you measured it to 2 or 3mm?Yes, the notch size of the trowel.
The floor seems pretty flat all over. The worst low spot I can find, in the kitchen, is 2-3mm. I haven't been able to check the hall yet but will when I lift the carpet, I expect it to be similar.
Reply to Bed thickness (600x400) 10 or 12mm? in the DIY Tiling Forum area at TilersForums.com
