Discuss Bull-nosing in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
Concrete guy
Cheers. I had it in my head that 2000 was as fast as you should go with soft marbles..
Im just considering a few options regarding a wet polishr and this one does get some good reviews.
The fixed speed wet polishers available tend to be fixed at around 3700rpm.
With Carrara you'd be better off with silicon carbide discs though, there's no upside to using diamond pads wet unless you're doing huge quantity or dust is an issue.
Points
1,223
On a rock in the middle of the sea.
Interesting.
And do you think dry polishing can produce as good a polished bullnose finish as wet?
dynamictiling
Points
568
glasgow
The reason I am posting these porcelain pictures in here is because I tend to treat the porcelain as stone using 1/16'' narrow grout joints, custom made shower shelf, bull-nosing etc View attachment 81504
View attachment 81501 View attachment 81503 View attachment 81497 View attachment 81498 View attachment 81499 View attachment 81500 Porcelain bull-nosing View attachment 81502
By the way that is some mighty impressive work, tops marks!!!
Out of curiosity, how long did that take you? What piece is on the end of your machine?
Tile Marble Granite
Points
758
Brownstown, MI. USA
Thank you!
It took me about 8 weeks to get that bathroom done, solo work, all custom made, water polished, joist reinforcement was done, waterproofing, plaster was taken off the walls as I do not tile on top of it, windowsill was replaced and redesigned/bull-nosed, shower shelf, toilet box with custom made access panel as seen in pictures. Time consuming I can tell you that. It is a ''Diamond'' router 3/8''
Concrete guy
How long does the router last or how many meters does it do,
In marble you'll get a comfortable 100 linear Meters when use wet. Use dry it reduces lifespan by as much as 30%-40%.
In limestone and travertine they go on and on.
We also offer a sintered version for abrasive materials like sandstone, we sell a lot of these to landscapers.
Lou
Admin
Staff member
Points
1,473
Staffordshire
Reply to Bull-nosing in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
