Discuss carpet tiles in the Australia Tiling Forum area at TilersForums.com.
dave l and l
going to lay carpet tiles in wee mans bedroom. thought process being that when he spills or rips a piece i can easily replace.
has anyone fitted them before. if so what adhesive did you use. i was thinking the carpet spray ahesive from screwfix would be the one .
Andy Allen
Points
1,318
Gloucester
Always Thought you loose laid them..so as you said you can replace them with ease...
If you stick them they could be a right pain to get up......still have nightmares now over some that I had to get up a few years ago in a office I was tiling.
dave l and l
yeah i am undecided on this. i was thinking about a small spray of adhesive just to fix them slightly so the child cant get his hands in and start to lift them himself,
jwoodhouse
as a plumber I sub to a shop fitting firm they spray adhesive the outside tiles and loose lay the insides if that makes sense plus the 2 going into any door way as they are the most susceptible to move
V
Vwoldboy
Hi everyone like to say hello as this is my first post on here.My son is a carpet fitter sometimes he lays floor tiles on commercial work and uses something called tackifier ? This holds the tiles down in position bot if you want to replace them they come up easy. It looks like pvaand he just spreads it out with a decorators roller hope this helps.
Taylormade
They are normally loose laid but very tight together which makes it difficult to get them up.
peteablard
Points
1,058
Cheshire
On commercial jobs I use F Ball F41 tackifier. You can use spray adhesive but you only need a very small amount. The idea is to stop them sliding not glue them down.If you loose laid them you'd have to make sure all the cuts were perfect as if there are any small gaps they'd all end up moving about
Russell brown
Not sure if this will work but as said above
Nope, just agreeing with the two people who said to use tackifier
Just Rizzle
use the spray adhesive. watched a carpet guy lay a carpet tile floor betweem the tiled bays I did recently he said the spray held them in place and stopped them moving on the sub floor.
dave l and l
thats it done. cut them in tight and sprayed carpet adhesive on the floor and a small bit on back of tile. checked the ones i started with and they seem to have bonded ok. time will tell. looks ok and it was easy to do. thanks for all the replies
Reply to carpet tiles in the Australia Tiling Forum area at TilersForums.com
  • Poll
Hi, I have a small en-suite 1200 x 2400, with a 1200 x 900mm linear drain tray which will have...
