Discuss Contractor installing 24x24 hexagonal tile on wall spot dabbing in the America Tile Forum area at TilersForums.com.
Points
36
Canada
Hello all,
I've recently gotten a contractor to do my washroom and he was installing tiles today, from what i've observed he has spot dabbed tiles onto the wall, I asked him if its fine and he said that the kerdi membrane behind the wall will not allow any water past it, the reason he's doing spot dabbing is due to the wall being extremely un even, as the house is 40+ years old. The floor base he did with kerdi membrane, then thin set and now he has added the mosaic tiles properly with a notched trowel and back buttered floor. My only concern is that will the wall tiles stay? could there be a chance that they fall off or even worse I get water damage behind the tiles and wall? please let me know, thanks.
P.S as far as I know he is not using the premix stuff only the bags of schluter all set cement.
Tile Marble Granite
Points
758
Brownstown, MI. USA
:)Dot & Dab is cutting corners, knowingly or unknowingly. I would call it cheap labor. Check out my website, you will then get an understanding of what you are dealing with.
Points
53
south England
Hello all,
Never spot fix under any circumstances!
Reply to Contractor installing 24x24 hexagonal tile on wall spot dabbing in the America Tile Forum area at TilersForums.com
