Discuss Deflection issue with No More Ply down in the DIY Tiling Forum area at TilersForums.com.
Deleted member 46792
To be honest there hasnt been much laughing in that bathroom the last couple of days...let alone any 'Elvis Willy'. :(
If put down a few more screws and it seems a bit better. I would consider ripping it up and starting again but from what ive read NMP + NMP megastrength adhesive is not something that is going to come apart from the underlying floorboards...
Andy Allen
Points
1,318
Gloucester
Go to screwfix get some 20mm turbo gold screws fix them every 300mm using an impact driver and see what it's like....should get rid of some of that bounce.
Joseph Kover
These are all structural-statical problems.not worth to risk,its all the traders fault from the moment he is touching it.
The bounce has definitely reduced with extra screws. I just used the No More Ply screws. I'm now thinking that maybe vinyl tiles is the only solution without ripping up the NMP and half of the floorboards they are now at one with.
Andy Allen
Points
1,318
Gloucester
TBH mate its difficult trying to make an assessment with out being there ...your dancing video help a bit and to me it looks like the nmp bouncing on the floor boards......personally I'm not a fan of nmp prefer hardie stuck down with a full bed of adhesive and screwed...
Choice is yours mate.....good luck.
Q
Qwerty
Personally I have never used NMP as I put my faith in other products. Strengthen the floor as already stated if you can and it should help massively
Used NMP once, you need more glue than they advise...I'll stick with Hardie.
Yeah i am surprised. I think this has been the problem. I have now added screws and there is very little deflection as far as i can see.
Andy Allen
Points
1,318
Gloucester
Go for it then....I would recommend using bal single part fast flex and bal wide joint grout with GT1 admix and 10mm notch trowel and back skim the tiles.
BTW....don't blame me if it fails :rolleyes:
Did a test area using bal single fast flex...its messy stuff and quite runny but so far so good.
I try not to blame anyone for anything, it rarely gets you very far. Unless its a question of losing things, and then it's always the Mrs hiding my stuff.
Dan
Admin
Staff member
Points
1,318
Staffordshire, UK
Reply to Deflection issue with No More Ply down in the DIY Tiling Forum area at TilersForums.com
