Discuss Floor self levelling compound in the Tile Adhesive / Grout Advice area at TilersForums.com.
Casper
Hi
My bathroom floor is not particularly level running out of true approximately 3mm. As most flooring covering manufacturers stress the importance of having a level floor I think that I need to use self levelling compound to achieve this. Can someone please recommend a brand to use as there are many out there but with wide ranging prices. I am not looking for a rapid set mix but one that gives a longish working time and ideally would like one that can be spread down to a feather edge as I do not want to increase the floor height anymore than necessary.
I have used BAL wall tile adhesive and see that they market level max but is 2-3 times more expensive than the cheaper brands. I only want to do it once so don't want to go cheap and regret it but also don't want to be ripped off. There are also some patches of vinyl tile adhesive left on the floor which is impossible to remove.
Casper
Floor area is 6.5 sq m. Am I worrying unnecessarily about the flatness ?. It seems to have a high ridge down the middle and falls away to the walls.
Ajax123
Points
1,213
Lincolnshire
blimey.. 3mm is pretty flat. if it is out by 3mm over a 2m edge it meets SR1 which is the standard that most floor coverings require. My bathroom floor falls by nearly 20mm across the width of the door... its a bu**er going to the loo in the middle of the night...
White Room
Especially if you've been on the liquid gold:)
Casper
No RSJ underneath the floor. If I put a straight edge across the floor it has ups and downs but no more than about 3mm. From your reactions it seems that maybe it is flat enough to lay vinyl or interlocking flooring without further preparation.
White Room
Ultra level2 goes down 2mm minimum , most adhesive will go up to 12mm some thicker.
One Day
Definitely!
Reply to Floor self levelling compound in the Tile Adhesive / Grout Advice area at TilersForums.com
