White Room
Pictures when can please.......
Discuss Help! in the DIY Tiling Forum area at TilersForums.com.
Will do. ThanksPictures when can please.......
I think he has spot fixed and will know when they come off next week. As for the pva why shouldnt he have used it and what should he have done. Thanks
Hi. One tile was taken off today.it was smashed so didn't have pic of it but here is the wall behind.it has been spot fixed if u can see on pic.also ll ok at the gap between the wall and other tiles.isnt this wrong? In one part you can push the measure 25 inches under the tiles before it hits any adhesive! The pics show the marks on the plaster off adhesive, the gaps between wall and tiles to the left, right and above the tile.what do you advise.should the whole wall be taken off and redone. There was also a radiator on the wall and the plumber has said it was because of that. A a a aah!Pictures when can please.......
Thanks for the comments. I will be phoning trading standards tomorrow for advice.That's just a dangerous install. All needs to come off. If you went the legal route you'd win easily and quickly. those pictures illustrate perfectly that quality tiling, like beauty, is only skin deep.
All off then.he wants to just take the ones off that have come loose!
Ok thanks so much for all advice.The ones he leaves behind will fail sooner than later...spot fixing isn't a recommended way of fixing tiles.
Reply to Help! in the DIY Tiling Forum area at TilersForums.com
