Discuss Help! in the DIY Tiling Forum area at TilersForums.com.
White Room
So why put plaster on if it is to be tiled?........... I wish more builders would just use render - half our problems with adhesive would stop straight away!
We used to just render on commercial sites in shower areas for the underground guys....
julie bw
Another point - in the original post you mention that the wall was only skimmed - is that correct as the clinker/building block should ideally have an undercoat on - that being a plaster coat or a sand and cement render before the finish coat. Please clarify because if it is just a finish coat the moisture absorption may be too high for any other coatings.
If the tiler would have said the tiles won't go on that wall or they need this and that doing I'd have gone with it so the job is done correctly even if it is a bit more expensive.with regards to that wall it is clinker block which had been mortared the skimmed as far as I can remember.
julie bw
The wall has never been tiled previously.
Dan
Admin
Staff member
Points
1,318
Staffordshire, UK
Reply to Help! in the DIY Tiling Forum area at TilersForums.com
