Discuss How much should I worry about this? in the America area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
I just set new porcelain 8 x 8 tile in my rear entryway (3 ft x 3 ft area). I love the results and wanted everything to be perfect and by the book. So, these two things are worrying me.
Worry #1: One of the tiles is touching a door frame in a couple of spots (see pic). The door frame is metal by the way (weird in a house, I know). There is at least a 1/8 inch gap elsewhere, and on two sides there is a good 1/2 inch that will be covered with baseboard. Is this tile going to pop off or crack in time, or is that not really a concern?
Worry #2: Where the tile meets the top of the stairs, it overhangs the Hardiebacker very slightly (see pic). Maybe 1/8" is unsupported along that last row of tile. There will be a wooden piece in from of that flush with the tile, so it would be impossible to stand just on that 1/8" bit that's sticking out, but I'm still worried it could chip or lossen. I was thinking maybe I should try to get a tile file and file off 1/8" all the way along, or maybe I should buy some expoxy putty and press it under there. If I did that, the epoxy would be resting on wood, and I wonder if that might cause other issues. Thoughts?
Thanks in advance for you're help with this.
Thanks, so no room for expansion is okay as long as it's just in a few spots? Also, won't the grout just fall out in that last 1/8" that hangs over (using epoxy grout)?
Reply to How much should I worry about this? in the America area at TilersForums.com
laattaana
