What are the advantages of 20mm boards against 10mm boards on top of concrete slab. Would the underfloor heating on top heat up any quicker or would the thicker board just prevent the heat from dispersing less
The thicker the insulation the more you insulate the floor from the cold slab. This will mean you will not need to turn the heating on as much, and when you do it will use less energy for a given room heat.
Reply to Insulation Boards thickness in the Australia Tiling Forum area at TilersForums.com
I am looking for 1 wickes Mississippi grey tile - damaged 1 tile in my kitchen and they have been discontinued 😭😭 looked everywhere online - wondered if anyone could help😞
https://www.tilersforums.com/threads/shower-bath-tiling-preparation-plaster-and-wooden-windowsill.83462/#gsc.tab=0
There was some heated argument in the above thread! I don't have much...
Hello,
I am a noob trying to tile our shower. Since the old tiles were taken off, some of that wall material has been taken off as well, so everything had to be smoothed. After smoothing with some...
This is the Brilliant Tiling Advice Provided and Peer-Reviewed via 1000’s of Tilers Discussion Thread
How do you know Tiling Advice is Trusted? When its peer reviewed and treated scientifically...
This is the A Friend of ours, UK Tiling Forum, is worth a mention for sure Discussion Thread
We have this Tile Blog here, and a few other websites lets say. We will be adding to the blog during...
